Shared TMC drivers SKR Mini E3 V3
Knew I should not have used these even if I had them. Can seem to solve this problem:
Here is the config extract:
[mcu]
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_48004D000950414733303120-if00
restart_method: command
[mcu zstep]
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_34002D000750414235363020-if00
#   X/Y Stepper Settings
[stepper_x]
step_pin: PB13
dir_pin: PB12
enable_pin: !PB14
rotation_distance: 40
microsteps: 32
full_steps_per_rotation:200  #set to 400 for 0.9 degree stepper
endstop_pin: PC0
position_min: 0
position_endstop: 120
position_max: 120
homing_speed: 25   #Max 100
homing_retract_dist: 5
#homing_positive_dir: true
[tmc2209 stepper_x]
uart_pin: PC11
tx-pin: PC10
uart_address: 0
interpolate: false
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 999999
[stepper_y]
step_pin: zstep:PB13
dir_pin: zstep:PB12
enable_pin: zstep:!PB14
microsteps: 32
endstop_pin: zstep:PC1
position_min: 0
position_endstop: 125
position_max: 125
homing_speed: 50  #Max 100
[tmc2209 stepper_y]
uart_pin: zstep:PC11
tx_pin: zstep:PC10
uart_address: 0                          If I change this to  "zstep:0"   then I get a parsing error
interpolate: false
run_current: 0.8
#   Z Stepper Settings
[stepper_z]
step_pin: ztep:PB10
dir_pin: zstep:!PB2
enable_pin: ztep:!PB11
rotation_distance: 32
microsteps: 16
endstop_pin: PC2
position_endstop: -5
position_max: 100
position_min: -15
homing_speed: 10
second_homing_speed: 5
homing_retract_dist: 3
[tmc2209 stepper_z]
tx_pin: zstep:PC10
uart_address: 1
interpolate: false
run_current: 0.6
stealthchop_threshold: 500
[stepper_z1]
step_pin: zstep:PB3
dir_pin: zstep:PB4
enable_pin: zstep:!PD1
microsteps: 16
#full_steps_per_rotation:200
[tmc2209 stepper_z1]
tx_pin: zstep:PC10
uart_address: 3
interpolate: false
run_current: 0.6
[stepper_z2]
step_pin: zstep:PB0
dir_pin: zstep:PC5
microsteps: 16
[tmc2209 stepper_z2]
tx_pin: zstep:PC10
uart_address: 2
interpolate: false
run_current: 0.6
#   Extruder
[extruder]
step_pin: PB3
dir_pin: !PB4
enable_pin: !PD1
gear_ratio: 50:17
microsteps: 16
full_steps_per_rotation: 200
rotation_distance: 13.760
nozzle_diameter: 0.400
filament_diameter: 1.75
heater_pin: zstep:PC8
sensor_type: Generic 3950
sensor_pin: PA0
min_temp: 10
max_temp: 270
max_power: 1.0
min_extrude_temp: 170
max_extrude_only_distance: 500
max_extrude_only_velocity: 7200
max_extrude_only_accel: 800
#max_extrude_cross_section: 50.0
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
##  Try to keep pressure_advance below 1.0
#pressure_advance: 0.06
#pressure_advance_smooth_time: 0.030
[tmc2209 extruder]
uart_pin: PC11
tx_pin: PC10
uart_address: 3
interpolate: false
run_current: 0.850
stealthchop_threshold: 0
And the pinout to the Mini E3 V 3
7 answers to this question
Well - problem solved - don't ask me how exactly but this is the steps to rectify the errors:
Clarification/Terminology:
Main Board = Primary board (BTT SKR MINI E3 V3)
Z board = Secondary Board (BTT SKR MINI E3 V3)
HARDWARE CHANGES:
1. Reviewed all the connections and realised I had my B Motor plugged into the Z-Board (the one named zstep)
2. Changed the B Motor over to the main board: Ensured I had A-Motor, B-motor and E-Motor plugged into the main board
3. Realised my X- and Y-endstops where on the Z-Board, and the Z-Endstop on the main board,
4. Swapped X- and Y-Endstops to main board and Y-Endstop to the Z Board
SOFTWARE CHANGES:
1. Changed the naming of the Z Board mcu to [mcu z] to avoid spelling errors
2. Played around with the [TMC2209 xxxx] section and after numerous restarts trying to exclude or include various statements, this finally worked:
[tmc2209 stepper....]
uart_pin: PC11
#tx-pin: PC10
#select_pins:
uart_address: 0
interpolate: false
run_current: 0.8
The end result of another morning of fiddling and being the stubborn Frisia Dutchman I am at a working configuration. Even got the neopixels on both bed and hotend working.
Thanks for everyones input
Case Closed
Have you tried just dropping the "uart_address" out altogether (leave the software to figure that out for itself) ?
I'l need to check some of my configs to see if I bother with it, I'm sure it's caused me more grief than anything.
This is a small thing and might be complete nonsense but I note that your uart addresses on the default MCU are non-sequential (i.e. 0 & 3) perhaps if they were (0 & 1). That's utter hand-waving but I know some address systems assume there's no gaps in the address range.
They are because of where the motors are connected.
XM=0, YM=1, ZMA, ZMB=2 and EM =3
Thus in flipper they need to reflect the connection and don't need to be in sequence.
