- 0
Shadow2
My Voron 2.4v1 Was sitting unused for about 7 months and after logging in i updated everything including Moonraker..After All was done i got a message" Cannot connect to Moonraker (192.168.0.20)
I downloaded moonraker config file and this is what i got...Printer ran flawless prior to update..i have been away from Klipper firmware for a while now and tried few things but still no go..it also gives me this message
If this message appears repeatedly, please have a look in the log file located at:
I'm using Octopus Pro With 2209's and rasp pie 4
[server]
host = 0.0.0.0
port = 7125
enable_debug_logging = False
config_path = /home/pi/klipper_config
log_path = ~/klipper_logs
[authorization]
cors_domains =
https://my.mainsail.xyz
http://my.mainsail.xyz
http://*.local
http://*.lan
trusted_clients =
10.0.0.0/8
127.0.0.0/8
169.254.0.0/16
172.16.0.0/12
192.168.0.0/16
192.168.0.20
FE80::/10
::1/128
[octoprint_compat]
[history]
[update_manager]
[update_manager mainsail]
type = web
repo = meteyou/mainsail
path = ~/mainsail
All Configuration Files:
/home/pi/klipper_config/moonraker.conf
2022-12-01 04:50:38,480 [moonraker.py:add_warning()] - [server]: Option 'enable_debug_logging' is deprecated, see the configuration documention at https://moonraker.readthedocs.io/en/latest/configuration/
2022-12-01 04:50:38,493 [app.py:register_local_handler()] - Registering HTTP Endpoint: (GET) /server/info
2022-12-01 04:50:38,494 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: server.info
2022-12-01 04:50:38,494 [app.py:register_local_handler()] - Registering HTTP Endpoint: (GET) /server/config
2022-12-01 04:50:38,494 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: server.config
2022-12-01 04:50:38,494 [app.py:register_local_handler()] - Registering HTTP Endpoint: (POST) /server/restart
2022-12-01 04:50:38,494 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: server.restart
2022-12-01 04:50:38,497 [moonraker.py:load_component()] - Unable to load component: (dbus_manager)
Traceback (most recent call last):
File "/home/pi/moonraker/moonraker/moonraker.py", line 250, in load_component
module = importlib.import_module("components." + component_name)
File "/home/pi/moonraker-env/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/pi/moonraker/moonraker/components/dbus_manager.py", line 10, in <module>
import dbus_next
ModuleNotFoundError: No module named 'dbus_next'
2022-12-01 04:50:38,497 [moonraker.py:main()] - Moonraker Error
import dbus_next
During handling of the above exception, another exception occurred:
File "/home/pi/moonraker/moonraker/moonraker.py", line 503, in main
server.load_components()
File "/home/pi/moonraker/moonraker/moonraker.py", line 231, in load_components
self.load_component(config, component)
File "/home/pi/moonraker/moonraker/moonraker.py", line 262, in load_component
raise ServerError(msg)
utils.ServerError: Unable to load component: (dbus_manager)
2022-12-01 04:50:38,498 [moonraker.py:main()] - Server Shutdown
5 answers to this question
