- 0
DennisM
I'm using protoloft's auto Z height code and I thought it's been working out.
But for some reason, the very first calibration is always way off -- often it thinks the calculated offset is 0, or negative numbers. Here's an example of running it 3 times in a row:
Z-CALIBRATION: ENDSTOP=2.230 NOZZLE=2.223 SWITCH=10.242 PROBE=7.185 --> OFFSET=-1.223500 Z-CALIBRATION: ENDSTOP=2.230 NOZZLE=2.228 SWITCH=10.240 PROBE=9.456 --> OFFSET=1.053000 Z-CALIBRATION: ENDSTOP=2.230 NOZZLE=2.235 SWITCH=10.738 PROBE=9.945 --> OFFSET=1.052000
The second and third ones seem correct, and when actually printing a test print I've confirmed they work and provide the right printing nozzle height. Has anyone come across this?
I think it's possible it might have something to do with my G32 macro, which I crafted together to grab the probe and do both the QGL and the Z calibration in one group, then stow the probe. Here's that macro:
##################################################################### ## Full calibration macro G32 ##################################################################### [gcode_macro G32] ## modified to support euclid probe and the new z calibrate klipper plugin ## https://github.com/protoloft/klipper_z_calibration gcode: SAVE_GCODE_STATE NAME=STATE_G32 G90 ; absolute positioning G28 ; auto home X Y Z M401 ; deploy euclid probe _QUAD_GANTRY_LEVEL_ORIGINAL ; QGL macro without probe deploy G28 ; auto home X Y Z BASE_CALIBRATE_Z ; calibrate Z height without probe deploy G28 Z ; home Z one last time M402 ; stow euclid probe, we're done G0 X150 Y150 Z40 F3600 ; move to center of bed RESTORE_GCODE_STATE NAME=STATE_G32
Note that the euclid.cfg file renames the original QGL to the one I used above. I don't want to use QUAD_GANTRY_LEVEL in the G32 as it includes the M401/M402 probe steps.
[gcode_macro QUAD_GANTRY_LEVEL] rename_existing: _QUAD_GANTRY_LEVEL_ORIGINAL
I'm working on a newly built 2.4r2 300mm with a Euclid probe.
5 answers to this question
