- 0
Anacardium
Hi!
My V0.2 is running fine. Printing is all good and now even better using the new improved Mini Stealthburner with Orbiter 2.0.
But: When ever I´m watching the camera feed of my Raspberry 2 cam, ping times increase and the video starts to freeze. Finally, the printer is not reachable any more.
Ping without watching camera stream:
64 bytes from 192.168.1.213: icmp_seq=10467 ttl=64 time=10.129 ms
64 bytes from 192.168.1.213: icmp_seq=10468 ttl=64 time=8.277 ms
64 bytes from 192.168.1.213: icmp_seq=10469 ttl=64 time=5.803 ms
64 bytes from 192.168.1.213: icmp_seq=10470 ttl=64 time=5.959 ms
64 bytes from 192.168.1.213: icmp_seq=10471 ttl=64 time=5.664 ms
64 bytes from 192.168.1.213: icmp_seq=10472 ttl=64 time=6.238 ms
64 bytes from 192.168.1.213: icmp_seq=10473 ttl=64 time=6.852 ms
64 bytes from 192.168.1.213: icmp_seq=10474 ttl=64 time=7.528 ms
64 bytes from 192.168.1.213: icmp_seq=10475 ttl=64 time=5.724 ms
Ping when watching the stream:
64 bytes from 192.168.1.213: icmp_seq=10566 ttl=64 time=35.601 ms
64 bytes from 192.168.1.213: icmp_seq=10567 ttl=64 time=110.564 ms
64 bytes from 192.168.1.213: icmp_seq=10568 ttl=64 time=25.575 ms
64 bytes from 192.168.1.213: icmp_seq=10569 ttl=64 time=304.525 ms
64 bytes from 192.168.1.213: icmp_seq=10570 ttl=64 time=730.814 ms
64 bytes from 192.168.1.213: icmp_seq=10571 ttl=64 time=375.876 ms
64 bytes from 192.168.1.213: icmp_seq=10572 ttl=64 time=409.942 ms
64 bytes from 192.168.1.213: icmp_seq=10573 ttl=64 time=529.365 ms
64 bytes from 192.168.1.213: icmp_seq=10574 ttl=64 time=427.653 ms
64 bytes from 192.168.1.213: icmp_seq=10575 ttl=64 time=1114.534 ms
Often it results in loosing the connection.
I already implemented a script as cron job which is checking ping time and resetting the connection if time goes over 50ms. But that´s only a bad work around, no real solution, of course.
My crownsnest config looks like:
Behavior is not as bad when using 640x480 and lower fps like 15. It takes longer to show the issue, but it is still there.
I´m running out of ideas.
Any suggestion what I could check or change is highly appreciated.
0 answers to this question
