Simultaneous MMUs
Bino
Is it possible to simultaneously control two different systems like a tool changer for multi-material while a MMU like TradRack is connected additionally to for example one of the toolheads?
Toolhead 0: PETG or ASA
Toolhead 1: PLA via TradRack
If you are using an SB with a CAN board, you are already using 2 MMUs. The trick will be having the klipper code/libraries for the MMUs functionality.
Something like:
[mcu]
serial: /dev/serial/by-id/usb-Klipper_Klipper_firmware_xxxxx-xxxx
#canbus_uuid: xxxxxxxxxx
[mcu EBBCan]
serial: /dev/serial/by-id/usb-Klipper_Klipper_firmware_yyyyyy-yyyy
