Unable to reach safe home
I'm working through the Initial  Startup sequence and have managed to go as far as locateing my Z end stop according to the directions.
I've found the x and y locations of the z end stop and inputted it into my home_xy_position statement.
When I issue a home command (home xy then home z or home  all) the gantry lifts, x homes, y homes and z will try to go to it's (-) position.
A couple of things I've noticed but also do not understand:
In mainsail when using the directional tabs the x or y will turn from orange to blue when selected but z only stays orange and will move only a few mm up no mater what option is chosen.
With a M114 command sent x and y will report the correct position but z always reports 10.
With GET_POSITION all z steppers report the same position.
Suggestions please.  TNX
A couple more things I forgot to mention.
When attempting to move z via the G1 command I get the error message: Must home axis first followed by the locations, this happens even from the X/Y home.
I'm using the  Voron print.cfg file from the Voron site. I've ONLY made changes to all the stepper dir_pin to get proper directional movement, added another fan and changed the home_xy_position statement.
I changed the position_endstop: from the negative number to 10.
When z attempts to home it still wants to go below the bed surface.
Am I missing another statement that tells z where the bed surface is?
When giving a M114 command x and y report correct positions but z is still reporting 10.
19 minutes ago, golddustpeak said:
When z attempts to home it still wants to go below the bed …
I don’t get you; when z homes the printhead should move to the correct xy position of you z-endstop and then lower the nozzle onto the z-endstop to trigger it.
That will then be your reference zero point.
How can it go below bed level when attempting to home z??
When G28 command is issued: x homes to end stop, y homes to end stop, z starts down and will NOT STOP without me issuing a command to stop it.
x never moves to the z end stop position.
I really think something is wrong with z or the set up for it I just don't know how to find the problem.
Should I be asking in some other places as well and if so where?
Your home_xy_position und safe_z_home seems to be wrong.
As per your description x homes, than y homes and then gantry lowers in that position to find z instead of traveling to z-endstop xy position first.
You have a 350 Voron 2.4. So home_xy_position should Not be 332, 350 which is basically all the way in the back right corner but more like 235, 350 or so.
Double check.
Did you follow
https://docs.vorondesign.com/build/startup/
