CW2 Single Gear Mod - Wood Grain Test
Simple mod to convert the CW2 into a single gear drive
In my case it mostly eliminated my wood grain artifacts.
This is more of a test and not a long term solution as you have to print slower.
If you can't fit your bearings in, use the version with higher tolerances (or some sandpaper/drill). Do not force them in as they will bind and won't turn smoothly anymore!
manual:
You probably don't need a manual.
- Standard 3mm Bontech shaft
- 2 needle bearings 3 x 5 x 7 mm
